查看: 8998|回复: 0
[Help] 消失模铸造工艺说明有关内容的翻译
签到天数: 299 天
发表于 2012-6-15 16:22:03 | 显示全部楼层 |阅读模式
原文如下:
Valid for the case that there are two or more patterns on the match plate. It is not permitted to mix the two different halves of the pattern( see different marking!) in drag and cope.
有请高手帮忙,谢谢!
GMT+8, 2026-10-26 05:15 , Processed in 0.023045 second(s), 23 queries .
