查看: 10584|回复: 14
[求助] 淬火压床
发表于 2007-10-6 22:27:26 | 显示全部楼层 |阅读模式
请问,谁了解世界比较有名的淬火压床。
如HEESS,还有哪些???
求租大侠
发表于 2007-10-8 22:58:42 | 显示全部楼层
美国GLESON公司的淬火压床在国内用户较多,天一机生产的Y9050淬火压床就是仿照GLESON公司的G537压床。
发表于 2007-10-11 14:08:15 | 显示全部楼层
能作淬火压床的在国内好像只有天一机,不过好像还是计划经济的体制,也就是说不是根据合同生产,而是根据自己的计划安排。你能赶上这批计划你就可以购买设备,否则就等下一批。
签到天数: 50 天
发表于 2007-10-11 16:55:27 | 显示全部楼层
美国格力斯的比较好,我们这有一台,用着还行
发表于 2007-12-4 22:50:30 | 显示全部楼层
回复 #1 yidianyidi 的帖子
德国有一家,柯林贝格,最大直径做到1200mm。
发表于 2007-12-4 22:51:29 | 显示全部楼层
请教该设备的脉动频率是多少?是通过什么硬件来实现的?
签到天数: 317 天
发表于 2007-12-5 12:33:56 | 显示全部楼层
希望大家上传设备图片如何?
发表于 2007-12-6 18:15:52 | 显示全部楼层
实际上格里森做压床也是副业!人家主要是做数控机床的
Products > Bevel Products
529/537 Quenching Machines
The Gleason No. 529 Quenching
Machine (Manual) and the No. 529
Process Controlled Quenching
Machine (PCM) are designed
primarily for rapid production
quenching of automotive ring gears
and other round, flat or cylindrical
parts up to 10.5" (266 mm) diameter
and 4" (102 mm) high. These
machines offer complete control
of the quenching operation, and
a host of user benefits, including:
? Reduced setup/changeover time.
The PLC has the capability of
storing setup data for 96 parts.
? Repeatable setups for reduced
scrap and consistent quality.
? Ease of use improves efficiency,
reduces labor costs and minimizes
operator’s error.
? Improved process control.
? Fault monitoring.
In comparison, the Gleason No. 537
Quenching Machine (Manual) and
the No. 537 Process Controlled
Quenching Machine (PCM) are
designed for quenching automotive,
truck and tractor main drive gears
and other flat, cylindrical parts
up to 28" (711 mm) diameter and
8" (203 mm) high. Excellent part
quality is assured with minimum
of distortion and positive control
of material hardness and uniformity.
Both models are offered new or
remanufactured machines.
发表于 2007-12-6 18:19:57 | 显示全部楼层
WWW.gleason.com
Can you speak english?
发表于 2007-12-6 18:35:28 | 显示全部楼层
还头一次听说这个heess
这个公司似乎比格里森还要专业!
发表于 2007-12-7 09:15:18 | 显示全部楼层
回复 #10 quench2008 的帖子
价格也比GLEASON昂贵。
发表于 2012-9-1 14:43:25 | 显示全部楼层
登录/注册后可看大图
我公司生产Y9065淬火压床。
产品视频: http://v.youku.com/v_show/id_XNDM3ODEwOTc2.html;
点评
请完善视频资料!  发表于 2012-9-2 09:48
发表于 2012-9-6 00:39:09 | 显示全部楼层
格里森主要做齿轮加工设备的, 磨齿机,滚齿机,
现在国内的压淬机床,见得比较多的还是,hesse,尤其在vw这样的企业里!
发表于 2013-3-19 10:31:03 | 显示全部楼层
有干锯片淬火的么?直径2500mm
发表于 2013-3-19 21:28:05 | 显示全部楼层
linyou1818 发表于 2013-3-19 10:31
有干锯片淬火的么?直径2500mm
有图纸么?我们做个圆刀片的淬火设备~如有需要可以联系我们,图纸可以发送至我邮箱:1737563999@qq.com。
GMT+8, 2026-10-29 06:52 , Processed in 0.030044 second(s), 25 queries .
