查看: 7341|回复: 2
[Discussion] about the non-martensite structure
发表于 2010-11-21 21:01:04 | 显示全部楼层 |阅读模式
as we know the non-martensite  structure are harmful to the fatigue property. But the thickness and shape of this structure is not defined. who have the test date to show what the thickness and shape is appropriatable?
签到天数: 1074 天
发表于 2010-11-22 10:04:29 | 显示全部楼层
the thickness and shape of  non-martensite ? How do you read the non-martensite ?
Generally,Check the hardness value  whether it is martensite structure.
签到天数: 108 天
发表于 2010-11-22 10:21:39 | 显示全部楼层
yeah,each kind of microstructure has its particular hardness value
GMT+8, 2026-10-29 00:29 , Processed in 0.022776 second(s), 21 queries .
