查看: 8954|回复: 2
[Help] what is wesley austin etchant
签到天数: 334 天
发表于 2010-11-8 16:28:23 | 显示全部楼层 |阅读模式
I got a microstructure picture, and it shows the etchant is Wesley Austin, I have no idea of it.
发表于 2010-11-9 10:25:18 | 显示全部楼层
'10% nitric acid and 10% sulphuric acid in water' from internet.
i haven't found the authoritative document. pls attach the microstructure.
you can input "wesley austin microstructure" searched by GOOGLE, then the 2nd infor is that.
签到天数: 334 天
 楼主| 发表于 2010-11-12 17:04:45 | 显示全部楼层
OH? Thanks.
GMT+8, 2026-10-28 13:39 , Processed in 0.023142 second(s), 21 queries .
