查看: 5110|回复: 8
[求助] 求18CrNiMo正火工艺 大师请进谢谢
发表于 2010-7-8 20:42:01 | 显示全部楼层 |阅读模式
技术要求: P+F要求1-4 级   BH165-240 没有贝氏体   工件2KG   急
发表于 2010-7-9 05:03:50 | 显示全部楼层
常规炉做这种工艺因该比20CrNiMo 更难控制!给常州中岳热处理的小陈吧!
发表于 2010-7-9 05:09:40 | 显示全部楼层
中岳热处理科技有限公司, 二OO八年六月组建!是一家从事研究与开发各类热处理工艺&设备的高新技术企业,并先后在重庆等重工业基地配套近90%的调质、 淬火、 等温正火的热处理设备和专业外协加工热处理。
我们拥有强大热处理技术骨干力量;是一支思维前瞻的团队,喜欢探究热处理,并善于学习总结各类金属材料热处理综合性能,孜孜不倦的致力于革新热处理工艺,我们严于热处理过程控制管理;使得我们的热处理品质具有出众的一致性和稳定性。为尊贵的客户建立热处理流程档案已成为一种习惯,有便于快捷高效的帮助客户提供最佳热处理技术解决方案!
我们自主研发制造的燃气加热有马弗网带炉、网带式等温正火炉、已多次填补了行业空白,并成功解决了如薄件变形、工件脱碳、批量处理不均匀等热处理技术难题。
我们将网带炉这种特有的稳定性和均匀性发挥到前所未有极致!率先在高端的等温正火领域运用有着出乎意料的理想效果,彻底解决了18CrNiMo 、20CrNiMo、20CrMnMo、20CrMoH、 55#碳素钢等高淬透优质合金钢锻件等温正火出现的贝氏组织和硬度金相不能”同时”合格现象。
网带炉运用在淬火工艺上,油淬破膜冷却技术已经能做到今非昔比的满意效果。
Introduction
ZhongYue Hot Treating Technology Co.,Ltd was established in June,2008. Our company is engaged in the research and the development high technology and new technology enterprise what each kind of heat treatment craft & equipment .And successively in Chongqing and so on heavy industry base necessary nearly 90% quenching and tempering, quenching, isothermal normalizing hot heat treatment equipment and specialized external cooperation processing heat treatment.
We have the formidable heat treatment technology backbone force. It is a thought perspective team, likes inquiring into the heat treatment, and is good at studying summarizes the various metalloids material heat treatment overall performance, exertion diligently in the innovation heat treatment craft, we are strict in the heat treatment process control management; Enables our heat treatment quality to have the outstanding uniformity and the stability. Has become one custom for the honored customer establishment heat treatment flow file, at one's convenience provides the best heat treatment technology solution in quickly the highly effective help customer!
We research and develop the manufacture the combustionheater to have Muffle net belt stove, the net belt type isothermal normalizing furnace independently, to fill the profession blank many times, and succeeded has solved like the thin distortion, the work piece decarbonization, the batch processing non-uniform and so on heat treatment technology difficult problems.
We display net belt stove this unique stability and the uniformity the unprecedented acme! Takes the lead to have the ideal effect unexpectedly in the high-end isothermal hot domain utilization, thorough settlement 18CrNiMo, 20CrNiMo, 20CrMnMo , H13, the 55# carbon steel contour through harden alloy steel forging uniform temperature appeared hot Bei organization and degree of hardness metallography stabilization.
The net belt stove utilization in the quenching craft, the oil-quenched broken film cooling technology already could achieve the today we are no longer as we have been the satisfactory effect.
签到天数: 52 天
发表于 2010-7-9 09:47:44 | 显示全部楼层
等温正火,普通炉子少量可做,对操作要求较高。如果是我,我直接给调质了。
发表于 2010-7-9 10:55:59 | 显示全部楼层
    那不一样,正火和调质是两种不同的组织! 正火温度要高于后期处理温度,齿轴类产品还有后期的渗碳或调质处理, 正火组织有利于后期的处理,且很关键,特别是有效的改善后期处理的变形量和这个产品的综合性能!气车齿轴坯基本都要正火处理
签到天数: 52 天
发表于 2010-7-9 20:30:47 | 显示全部楼层
我个人不认为调质比正火差,或许加工上稍微困难点,但这应该不是问题,你要的硬度也不算低哦
发表于 2010-7-9 21:13:18 | 显示全部楼层
tlx322 发表于 2010-7-9 20:30
    没错: 在正火得到的是非珠光体组织的话,的确还不如调质的回火索氏体好!可理想的正火组织和调质组织是不能相提并论的! 就好比一个念了大学一个上了初中,受过了不同的洗礼,区别总是有的!
签到天数: 52 天
发表于 2010-7-9 21:23:01 | 显示全部楼层
哎,无语,我的观点,只要能符合性能要求,符合生产实际的工艺都是好工艺,而不是一定要按照一个不变的路线去走下去,你说的那几个疑点其实照样可以用调质解决掉,至于怎么解决,看你自己了,目前我还在试验另一种方式,如能成功,很多以往很难解决的一次性就OK了
发表于 2010-7-10 08:08:31 | 显示全部楼层
哎,无语,我的观点,只要能符合性能要求,符合生产实际的工艺都是好工艺,而不是一定要按照一个不变的路线 ...
tlx322 发表于 2010-7-9 21:23
    好样的!兄弟,搞热处理有时就要一根筋, 只要自己付诸了努力,热处理的最终品质其实就在你手里!我也相信调质在一定条件和要求下,可以取代正火
GMT+8, 2026-11-1 13:46 , Processed in 0.025199 second(s), 21 queries .
