查看: 3678|回复: 1
ASTM A575-96 (R2013) Standard Specification for Steel Bars, Carbon, Merchant ...
签到天数: 3046 天
发表于 2024-5-22 06:39:43 | 显示全部楼层 |阅读模式
ASTM A575-96 (R2013) Standard Specification for Steel Bars, Carbon, Merchant Quality, M-Grades
This standard is issued under the fixed designation A575; the number immediately following the designation indicates the year of
original adoption or, in the case of revision, the year of last revision. A number in parentheses indicates the year of last reapproval. A
superscript epsilon ® indicates an editorial change since the last revision or reapproval.
This standard has been approved for use by agencies of the Department of Defense.
ASTM A575-96 (R2013) Standard Specification for Steel Bars, Carbon, Merchant Qua.pdf (1.03 MB, 下载次数: 17)
签到天数: 1779 天
发表于 2024-5-22 08:35:09 | 显示全部楼层
ASTM A575-96 (R2013) 碳钢、商业质量、M 级钢棒的标准规范 该标准以固定名称 A575 发布;紧随名称后的数字表示最初通过的年份,或者在修订的情况下,表示最后修订的年份。括号中的数字表示上次重新批准的年份。上标 epsilon ®表示自上次修订或重新批准以来的编辑更改。该标准已被国防部机构批准使用。
GMT+8, 2026-10-26 19:11 , Processed in 0.024348 second(s), 24 queries .
