查看: 8957|回复: 0
[已解决] 马氏体气阀钢相变温度集锦
签到天数: 104 天
发表于 2022-11-22 11:46:28 | 显示全部楼层 |阅读模式
马氏体气阀钢相变温度集锦
今天我收录了马氏体气阀钢的相变温度,供有需要的朋友借荐使用,收录见下表:
钢种
Ac1(℃)
Ac3(℃)
Ar3(℃)
Ar1(℃)
Ms(℃)
备注
51Cr8Si2
867
925
815
795
285
文献摘录
42Cr9Si2
890
970
860
810
190
自测
45Cr9Si3
910
1000
895
850
自测
40Cr10Si2Mo
850
950
845
700
280
摘自《中国航空材料手册》
实际的相变温度与钢的成分、奥氏体化温度、升温速度及降温速度等有关,上表数据仅供参考。
Phase TransitionTemperature Collections of MartensiteValve Steel
Today I collectphase transition temperatures of martensite valve steel to use for friends inneed.See the table below:
Steel grade
Ac1(℃)
Ac3(℃)
Ar3(℃)
Ar1(℃)
Ms(℃)
remarks
51Cr8Si2
867
925
815
795
285
Extract from literature
42Cr9Si2
890
970
860
810
190
Self test
45Cr9Si3
910
1000
895
850
Self test
40Cr10Si2Mo
850
950
845
700
280
Extract from《China Aviation Materials Manual》
Actual phasetransition temperatures of martensite valve steel usually relate to theircompositionsaustenitizing temperatures,heating rates and cooling rates, so thedates in the table above are reference only.
2022.11.21
GMT+8, 2026-10-28 16:44 , Processed in 0.023452 second(s), 21 queries .
